rockford fosgate vs memphis
Rockford Power amps are extremely underrated, so if the prices are similar I'd go with the Rockford (but be careful with the extra power your sub would be getting).
memphis disregarding price and defiantly with price. the prd is like half the price. You can get a mcd 1100 for cheaper then the RF. it would be much better then the rf.
ok, i can get the memphis for $599 or the rockford for $620. i know they both are excellent amps but im still not sure which one, especially with a $20 difference.
Rockford T1001s usually put out 1500-1600+ watts. They're extremely solid amps, I wouldn't even consider a low end Memphis in the same price range.
Your punch Hx2's are only 500 watts each:fyi:
And I would purchase a T10001bd for them. Or even an older model 1001bd amp.
You can find a 1001bd for 250-300 on ebay. And are great under rated amps.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
bgbassmn
bgbassmn
ut
tiger777
slater
    May 2, 2024
slater
    May 2, 2024
