Rockford Fosgate T10001bd @ .5 ohms
quick answer if it does not rate at .5 ohms in the specs, then chances are its a no no to run at that ohm load.
im saying yes. I owned a 2000 and ran it at .5 and .75 and had absolutely no problems from it. daily and everything, only got a little warm on the black heatsink internals were fine. those amps have the best cooling of any amp i have ever owned the fans do a excellent job of circulationg the air keeping the internals cool.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
holla105
holla105
ma
jamesw
pfft
    May 1, 2024
pfft
    May 1, 2024
