Rockford Fosgate T1 Box Help
  • 5
Personally I would go ported there is no reason why the proper ported box can't have decent sq additionally ported boxes are most often louder and more efficient than sealed so if you have the space go with ported.
Ok the person i bought this sub from had it in a ported box and it hits the lows real good but some of the higher bass notes were not very loud at all. So i dont know if the box he had it in was just tuned wrong or what?
The sound or range of frequencies would definitely depend on the tuning or he may have had his low pass turned down a little to low the type of music you listen to generally is a determining factor in what frequency you tune your box to.
If you knew all the measurements of the box including the port length or if you still had his number you could ask him I'm sure he wouldn't mind telling you if he knew.
You could try plugging those numbers into Torre's box calculator to see what you come up with I'd do it but I use a mac and it's made for windows //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
He said the box size was 22x15x13 and the port length was 18. The box was made out of 3/4 wood also
You would also need to know the port opening ( H x W).
However, just because that enclosure performed the way it did in his application, does not mean it would the same in yours.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
Brandon9
Brandon9
michigan
goingdef
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
