Rockford Fosgate Punch P400x4 Amp - $140 shipped
  • 2
Murphy_Smith
Rockford Fosgate P400x4 Amplifier
This amp is pretty much brand new. It came with a new vehicle purchase and was installed. Amp was removed by local stereo dealer with 24 hours of vehicle delivery. I can't find a scratch or smudge on it.
Don't have the box or the manual. I will ship in a very well packaged package.
Here are the specs on this amp from Rockford Fosgate.
CEA-2006 Compliant: CEA-2006 GuidelinesCEA-2006 Power Rating
50W x 4 @ 4Ω
≤1.0% THD+N
Number of Channels: 4
Rated Power
(RMS Continuous Power): 50 Watts x 4 @ 4-Ohm
100 Watts x 4 @ 2-Ohm
200 Watts x 2 @ 4-Ohm Bridged
Total Power
(Sum of Rated Power): 400 Watts
Dynamic Power
(PVC/PowerCube®): 82 Watts x 4 @ 4-Ohm
137 Watts x 4 @ 2-Ohm
266 Watts x 2 @ 4-Ohm Bridged
Bridgeable: Yes
Frequency Response: 20Hz to 20kHz +/- 1.0dB
Efficiency (average): 67% @ 4-Ohm
Total Harmonic Distortion(THD+Noise): 4-Ohm:
2-Ohm:
Crossover Controls: Front High-Pass/Low-Pass (HP/LP): 50Hz-250Hz @ 12dB/octave Butterworth
Rear High-Pass/Low-Pass (HP/LP): 50Hz-250Hz @ 12dB/octave Butterworth
All-Pass: Yes
Tone Controls: Front Punch EQ2 Bass: 0dB to +18dB @ 45Hz and/or
Front Punch EQ2 Treble: 0dB to +12dB @ 12.5kHz
Rear Punch EQ2 Bass: 0dB to +18dB @ 45Hz and/or
Rear Punch EQ2 Treble: 0dB to +12dB @ 12.5kHz
Function depends upon LP/AP/HP switch position
Input Sensitivity: 150 mV - 12 V
Signal Input: Hi/Low level: 2 RCA pair
Signal Output: -
Power Input Connector: Captive C-Clamp
Power Wire Gauge: 8 AWG to 4 AWG
Speaker Output Connector: Captive C-Clamp
Speaker Wire Gauge: 8 AWG to 18 AWG
Heat Sink Type: Cast aluminum
Cooling: Convection
Remote Controls: -
Visual Indicators: Power/Protect/Thermal LED
Input Clip LED
Output Clip LED
Circuit Topology Class: Class-A/B
Operating Voltage: 9 - 16 VDC
Recommended Fuse
(not included): 60 A
Max. Current Draw (13.8V Sinewave): 60 A
Average Current Draw (13.8V Music): 30 A
Suggested Alternator: 75 A
Shipping Weight: 10.8 Lbs. (4.89 Kg.)
Dimensions (H x W x D): 2.38 x 7.76 x 11.03 (in)
6.05 x 19.71 x 28.02 (cm)
Dimensional Diagram:
$140 Shipped
FedEx ground
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
Murphy_Smith
Murphy_Smith
Dallas, TX
woody70
    May 16, 2024
    May 16, 2024
