RF 3Sixty.3 Power Harness is missing...
  • 2
Ha. I didn't think about that but you're right. But I'm a non DD part too and so far I'm not the bottle neck either.
I just hope I don't become it. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
In other news, I got a 1400.1 in the wife's van and I worked on that sub for another hour or so. Broke the last 1/8" of coil off too so it's a lost cause. So now I think I'll load that sub in the big t-line and turn the gain all the way up on the amp and just see how long it takes to get the smoke out of the one good coil.
Should be a fun experiment for next weekend at the Turkey Drag. //content.invisioncic.com/y282845/emoticons/idea.gif.5acb6a39a9b92425414c316dda202bad.gif
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
518
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
387
798
drockstar
drockstar
Shreveport, La
drockstar
    May 12, 2024
Brendon Jenness
    May 11, 2024
