Review my budget build
what amp are you planning on running the sub off of? because either one of those amps would not be ideal to run the sub. I would probably use the kenwood to run the mids and look into a different amp for the sub. Probably something with a mono output as that sub is dual 4ohm and most 2ch amps bridged wont like that.
hmm yea I just did some research into that. Should I use an amp for speakers or the sub, which will have a better effect? Idk which one to get for the sub I'd need to look.
JAGX
JAGX
Buffalo, NY
ObTechAudio
