Resonant Engineering 10" SX Box Build
Day 3:
Okay Uneasy Update.
Here's the Situation:
I have holes in my wood the same size as the holes on my sub. vv
I have Nut's, Washer & Bots holding in my sub instead of screws. vv
As a result, I can't use the rubber lip that goes around the rim of the sub vv
My neighbor insisted on doing thing to better support the weight of the sub but now I feel it may of been a mistake in more ways then one
I need to unscrew roughly 15 screws on the top of my enclosure to get to my sub vv
After that i need to take a socket wrench and undo 8 nuts, 5 awkwardly located vv
After all this I to put it all back together.
My box has still not been fabricated nor has the exterior been painted.
Pro: Its solid as fuh. My sub isen't moving a inch while installed
Cons: Just about everything listed above.
Should I fill the bolt holes and drill new holes for screws? If yes, how do you suggest I do so?
Pictures will be posted asap.
I'd fill in the holes and just use screws for the sub. It's not a super heavy sub, so there's really no need for bolts or anything like that. I'd just use the same coarse thread drywall screws you've been using, they grip MDF like a beast. Just use a 1/16-7/64" drill bit to predrill.
haha sounds like the "RE" logo is going to tilting a little bit then. hopefully i can have this finished by this weekend. need wiring tho. found my power wire from my last subs but still looking for my ground.
Fabricated
Rounded edges made the job a difficult one but all things considered, I give it a C+
from the front view at least.
All I need now is wiring and I'm set. Might go to best buy for that, just to be done with it. Get the wires, fill the hole in the back, throw it in the trunk and go.
I found the thread and responded to it sir! Consider these SOLD!! Please Check your Payment transaction. I thank you
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
997
Sweet'n Low
Harshaw
Sweet'n Low
Springfield-Dayton, OH
RAM_Designs
    May 16, 2024
    May 16, 2024
