Resin inside of box?
what is the purpose other than wasting time and $$$$.....
Caulk to seal the joints if your cuts are off......wax if you want a slippery surface. If you need strength then add bracing as resin does nothing to make a box stronger unless you use fiberglass mat and that won't be fun....
Resining the inside of the box seems like a lot of work for no real gain. I can add silicone caulk to the corners like dude mentioned above^. If your looking for smooth air flow, maybe a layer of paint to help make the internal surface be smoother. If your looking at adding strength, try extra bracing
it lowers the resonance, strengthens it and seales it. wood is pourious reguardless.. ive put up better numbers by just doing two coats of resin
you talking to a guy that has built more 156 db+ cars than you ever will in your lifetime lol.
i dont care, ive built plenty on system and it has made a difference. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
---------- Post added at 09:53 AM ---------- Previous post was at 09:53 AM ----------
What did U gain .01db..... Resin isn't worth it.
.2 hehe
disturbed471985
disturbed471985
Greenwood, La
Papermaker85
