Removing Factory VW Radio w/o the removal keys???....
if ;you have the slides from an aftermarket cage release tool, you may be able to convice the latches to release, but I would probably wait for the right ones.
Otherwise this would be the one in a million time to go to walmart and buy them for five dollars.
Is it the four hole type removal process, euro din? If so, you can take a wire coat hanger and cut off the ends and use that. It's very simple; just cut the hanger, bend them so they slide into the four holes and then pull to the right and left of the stock receiver. It will just come right out.
x2....he beat me to it, my friend did the exact same thing so he didnt have to buy the pins to remove the radio
NeverEnuffBass
Got Bass?
NeverEnuffBass
Greenwich, CT
PepsiFiend69
