remove motor from type r ?
nutznboltz
unscrewed the bolts, and gave it a couple whacks, and nothing.
should i apply heat? beat the hell outta it till it comes off?
also, the coil worth anything, or trash it?
It probably isn't threaded, but it doesn't hurt to try twisting it. That way you're not breaking anything in case there are threads. If you have to pry up, make sure you get something that will pry near the base so you don't crack the magnets or dent anything.
i used acetone to soften up the glue around the screws..... cant get my motor off either...?!?!?!
even tried with a rubber hammer!
im pretty sure they dont unscrew, but it makes wana go grab it and try!! hahaha
nutznboltz
nutznboltz
colorado
9515ROB
