Remote turn on wire help?
Im doing a install in my 2012 srx. I have everything wired up but the remote to the amp. The fuses I have tried so far stay on for about 2 to 3 minutes after I cut the car off. Does anyone know which fuse I need to be tapping for the remote? Thanks.
When you cut the car off, doesn't everything shut down after you open the driver's door? My stereo stays on for a few minutes when I turn my Mustang off, but cuts off when I open the driver's door. The same feature on my 2012 SRX. I like that feature, as I can continue to listen to my music for a few minutes. Just a personal choice.
Yes, exactly what's happening. I found out it also was my cheap loc I installed. I think I got a defective one. Although it's powered it was staying on a little longer. I unhooked the power portion of it, and it still cuts the amp on. So, I will try to find another one.
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
212
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
985
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Actually, I think I had the adjustment knob turned down while I was setting gain! Rookie mistake
31
4K
Levelup1
CarAudio.com Recruit
Levelup1
North Carolina
Levelup1
saints747
    May 7, 2024
saints747
    May 7, 2024
