Remote turn on for amp - whats and hows?
  • 4
oysterman
UK
Hi,
I've just purchased an Alpine MRV-F300 amp and a JVC KD-X341BT (thanks to everyone who helped in this forum for getting me this far). I noticed the amp has a remote turn on connection which is wired to the head unit, but connector to be bought separately.
1) Is this a special cable or something I can make myself?
2) Can it be wired to any head unit (+ve out) or only head units that have a 'live out' feature when turned on?
3) How does this work, technically? Does the amp recognise a connection simply because a wire is connected and only allow power to the amp when receiving a signal through this cable? Or is it an alternative power source?
Keen to wire this up if I can, so any pointers appreciated, thanks.
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
344
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Actually, I think I had the adjustment knob turned down while I was setting gain! Rookie mistake
31
4K
oysterman
oysterman
UK
oysterman
    May 18, 2024
    May 18, 2024
