Remote on monsoon stereo?
  • 2
Malachite99
I want to install an amp and 2 12" subs to the factory monsoon deck in a 2003 Pontiac Grand Am GT. What I really need to know is if the monsoon deck has a remote wire or power antenna wire for the amp. If not, how would one wire the amp so that the amp turns off with the radio?
I'm pretty sure it would have a remote since it has a factory amp, but i'm not positive on that, go to your dealer and get wiring diagram to find out for sure. Youre definitely going to need a Line Output Converter though.
Good point....I never took that into consideration. I'll double check with the dealer to make sure though. Thanks! And as for the line level converter...don't think I'll need it. The amp has a High Level input so I'll probably just tap into the rear speakers for a signal.
Actually i'm positive it has a remote wire, because i hard wired a bass light in my friends 02 Grand AM GT and tapped into the remote wire, im pretty sure its the blue/white one, although it may be blue i really dont' remember.
What kind of amp?
It's a 300 watt crossfire amp. It's somewhere around 4 years old. Before I replaced the deck in my previous car (a 94 cavalier) I tapped the rear speakers for a signal as well...so I know that will work. When I replaced the deck I just ran a line from the decks pre-outs to the amp.
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
541
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Actually, I think I had the adjustment knob turned down while I was setting gain! Rookie mistake
31
4K
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
Malachite99
Malachite99
Columbus, OH
Malachite99
    May 24, 2024
