Recommended electrical for ~4.5k?
Maybe you're talking about the added load from a discharged cap? It's actually pretty much non existent unlike in standard caps. The resistance of an ultracap is nearly zero, so there's no extra load.
Also music is dynamic, you're not going to see much of a drop unless you're playing tones for more than a burp.
Quote from TaylorFade
Source: (this 20 page thread with tons of info from T-Fade and KHA)
Capacitors are cool
I was also skeptical at first. But after some pretty extensive research, they have really impressed me.
---------- Post added at 10:01 PM ---------- Previous post was at 10:01 PM ----------
Refer to my last post
These caps can store and discharge very fast but there's a problem, once they dump that's it where as a good battery has a lot of reserve current. A good one can charge just as fast also
this is why i run the odyssey batts.ran xs ,batcap ,kinetik and a few others ,these are far superior
A good battery can NOT charge anywhere near as fast as an ultracap; the resistance is too high. Like I said, an ultracap's resistance approaches zero - so charging is near instantaneous and voltage drop is nonexistant. Also there's still the voltage drop to 12-13v that accompanies a battery (once again due to the resistance of the battery and inability to hold a charge much higher than it's voltage rating) - ultracaps hold the alternator's charging voltage.
I believe there was some testing done that showed a single bank of ultracaps supporting a 500a current for 5 seconds before dropping to the voltage you'd expect to see from a high quality battery. If I find the thread I'll link it for you. Note that a continuous 500a draw is NOT going to happen on music in 99.9% of setups. If so, you could just add more banks, anyway.
EDIT: that test was also done with no alternator/charging system supporting the ultracaps
Caps have a place in classes that limit batteries but what do you still see in classes that don't? A good battery should have no resistance at or above resting.
People have done a lot of testing with caps, and caps are always louder than batteries. Doesn't matter how big of a battery bank it is. Testing was also done with batteries and caps, and it was still louder, but still not as loud as caps alone.
I dont have any experiance with caps. I'm basing judgment off what I see. Dante and Butler don't use caps and I'm sure they could if they wanted to. Neither does any big ground pounder
akillj
akillj
CA
Chriszle
