Recommended electrical for ~4.5k?
but thats at 2000 + rpm .true test is at idle ,how long can you go ?
My bypass cuts the alt off under 700 rpm. It will sit above 12.6 for a few minutes of bass mekanik stuff. If its cold and stays on it don't drop. Heck DD is telling me ill be able to power that m4a with what I have.
Smaller HO alt, upgraded under hood battery, and spend the money you save on one or two banks of ultracaps //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
not bad at all.i'll be dong over 500 amps of alt juice in my truck soon .with 7 pc 2150 batts have 5 batts already waiting to go in
might be ok ,you do realize that i am the local xs power dealer in your area ?
I didnt know that? I'm just planning right now, no money to buy anything at the moment. I will contact you when I get more money though.
And thanks for the suggestions guys. Much appreciated.
How good are those caps going to be with no power to pull? Just another load adding resistance.
any time man ,i'm actually 30 min south of you. i was in morgan hill for the forth all day
I can't fit duals **** it. If so I'd drop the account on goodies. I guess it's a good thing.
that sux , i already have 2 200 amp alts ,but gonna send one to mike and have it built to 350 amps ,then going to have my local alt guy make the bracket and install both alts with the external reg .should see 550 amps at 2000 rpm and 285 at idle
Ultracap banks outperform battery banks every day of the week. Taylorfade was running a m4a off a stock alt (110 amp if I remember correctly) and 2 banks of ultracaps and didn't really dip below 13.5.
Must be nice. I had a great offer on 2 m4as with 2 DDz 12s. I don't have room under the hood or in the back to do it. I own to much to sell the car. It's a blessing
---------- Post added at 10:57 PM ---------- Previous post was at 10:56 PM ----------
That's fine and they do work great but they have to have power passing to store it. Same as a battery.
Doing what though? I'm not being a smart ***.. Just curious. Is he just letting burp now and again or can he actually demo with it full tilt?
very nice ,last year i sold all my big equipment ,had bills to pay ,but now i'm rebuilding .and bigger than last time to .looking for a 156 db on music daily
Maybe you're talking about the added load from a discharged cap? It's actually pretty much non existent unlike in standard caps. The resistance of an ultracap is nearly zero, so there's no extra load.
Also music is dynamic, you're not going to see much of a drop unless you're playing tones for more than a burp.
Quote from TaylorFade
I actually use them in the daily too. I was running a DD M4a on OEM everything + (2) banks and I had to REALLY try to get my voltage below 13.5v. That's a 6k amp at 1 ohm on OEM electrical.
Source: (this 20 page thread with tons of info from T-Fade and KHA)
Capacitors are cool
I was also skeptical at first. But after some pretty extensive research, they have really impressed me. Think of it like this: the average amperage draw of music is not going to be much more than a stock alt can handle. It's just the spikes that cause voltage drop. Ultracaps smooth out these spikes. Even if it's just a little too much for your stock alt, add a small HO alt and you're taken care of.
---------- Post added at 10:01 PM ---------- Previous post was at 10:01 PM ----------
Refer to my last post
akillj
akillj
CA
Chriszle
vegang
vegang
