Recomend me a set
Based on the numerous reviews, midbass might be a concern though, imo. Based off of that, I wouldn't recommend anything less than 2x120w rms.
They're 60 watt speakers. 75 wrms should be fine unless he plans to listen to them at extremely high volume levels. If that's the case, then he might want more power to prevent amp clipping and to provide more headroom.
The manufacturer usually lists rms in 2 ways: 1.) full range, or 2.) a conservative fail-safe when a HPF is used. Just as much as max watts is a useless rating, so is rms imo. I see it as merely a baseline.
I agree 100%, but I've rarely ever seen speakers that actually REQUIRE 2 to 3 times their RMS rating in order to sound good. MOST speakers sound just fine feeding them anywhere from their RMS rating, to 1.5 times that rating.
And I agree with you 100% here, but there are always exceptions to that rule of thumb. One being the RSd comps when trying to get the midbass potential out of them.
ivanfbi
ivanfbi
Seattle WA
tcguy85
