Rear loaded horn enclosure question
This is what Pete at PWK said:
None. Just like there are no advantages of a bass-reflex (ported) box over a rear-loaded horn. Depending on the enclosure’s surrounding environment, woofer parameters, target response, and target listening point, one alignment may perform better than the other. And those just two options. Again, depending on the above stated variables, a transmission line may outperform both bass-reflex and a rear loading horn. Perhaps a 4th, 6th, or 8th order bandpass, perhaps a tapped transmission line, front-loading horn, tapped horn, aperiodic bass-reflex, Voigt pipe, etc…
Pete
Higher efficiency across a greater portion of the audio spectrum. Instead of being tuned to a single frequency, horn-loaded enclosures are essentially tuned to every frequency before the drop-off point. Very desirable in SR applications.
They also typically can't get as low as a ported box given limited space.
//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
But you could design it to hit as low?
You can achieve a flatter freq. response, greater cone control/mechanical power handling, and more output over a certain range. Very efficient boxes. They play lows, but don't have the bloated low end most people like. The tonal quality can be great though.
This is given they are designed properly in the right application.
Pete
Is it just me, or does that make no sense?
Buck
little alien on campus
Buck
Inside of a pyramid
rival904
