grimreper912003
<- getting a jAy eL 21W8
What are you gonna run for batts? The V4000xd is a current hog...if you get too large of voltage drops you will just blow the FETs again.
im thinking just getting the FI Q since it still can be played at low levels untill i get enough money to get a reconeAnd if you can use the RE motor and the Q soft parts you might be able to have someone else rebuild it for you, which ever ends up being cheaper.
i think its like 120amp im not sure its not really the GM stock its a replacement ust a little bigger than the GM original i had my homies lightning audio S4.1000.1D amp and the lights dint dim or nothing and he had it in his crown vik and the lights **** there went uut the same with my brothers old 76 caprice classic the lights dimed alot on both of them but the most i got was my dome light twitched barly even enough to notice itdont get a cap and buy a batt. PM bumping buick, as he has som stingers for retty cheap. how many amps is ur alt? I would NOT run this amp on 1 batt with stock alt. Snoopdan would prolly be ur best bet on recomendations for running this amp as it is the same board as the ma HK4000d.
i tryd PMin him it says he cant be founddont get a cap and buy a batt. PM bumping buick, as he has som stingers for retty cheap. how many amps is ur alt? I would NOT run this amp on 1 batt with stock alt. Snoopdan would prolly be ur best bet on recomendations for running this amp as it is the same board as the ma HK4000d.
im probly not gonna even be running it at 2ohm for awhile probly at 4ohm with gains turnd downtry it and watch your Voltage if it drops too much time to add another but one should be ok as long asyour not running it at 1 ohm or something stupid.
