RE Sub "PLEASE READ"
Thank you for the quick responces. I could not find reaudio.com for the life of me.
I'm having the RE 8 installed and the audio shop wanted to know the RMS, ohms etc etc. They wanted this info so they could decide on a amp. I think they carry MTX as their primary amp. Any suggestions?
I've tried calling 6-7 times and I just get the recording. No way to leave a message.
ahhh okay.
-but-
they shoulda been able to measure dcr on their own... //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
-Nick
Is this going in a small sealed, i wouldn't hesitate upping the wattage to 200rms or even 250 rms. peace
NG
P.S. obviously you can tell by looking, BUT if it had 2 voice coils...it's dual 4. BUT, the earlier re8's were SINGLE 2ohm. So, if you have one VC it's 2ohm.
this should help you out
RE8 RE10 RE12
Fs 22.8 Hz 21.5 Hz 20.0 Hz
Re 3.2 DVC 3.2 DVC 3.2 DVC
Qms 4.21 4.37 4.27
Qes 0.38 0.39 0.42
Qts 0.34 0.36 0.38
Sd cm2 195 322 500
Vas 27.1 l 75.6 l 182 l
Xmax 12mm 12mm 12mm
BL 15.4 15.4 15.4
SPL 81.2 84.7 87.3
RMS 175 W 175 W 175 W
Max 250 W 250 W 250 W
Additional info
Cutout 7.25 n/a n/a
Disp. 0.09 n/a n/a
Mndepth 4" n/a n/a
Weight n/a n/a n/a
Thanks for all the info. I think the shop is going to go with a 200W MTX amp. How does the ohm thing work... is 2, 4 or 8 better? I think he mentioned installing a 200W MTX and something about 2 ohms.
I don't understand any of this stuff. I simply want to cleanup the sound while keeping the factory stereo. It's a Lariat and has a decent system, but I'm sure the sub will make a world of difference.
Thanks.....
None are better, just different options and determines how much power you'll get out of the amp. DVC's give you more options for amplifiers (generally) since they can be wired into more than one impedence.
I'm not for sure, but I think they might go with-
Thunder282 2-Channel Amplifier
The crossover on this work-horse, 2-channel amp is 18dB/octave at 85Hz, switchable from low pass/high pass or full-range. Each features a buffered, isolated full-range output. This lets you daisy chain amps to other subwoofer amps or to high frequency amps. If you plan to use the high level inputs from the factory radio, our "Smart Engage" auto-turn-on circuit makes installation a snap - you won't have to remove the factory radio.
Download Owner's Manual in PDF form.
Download the Quick Install Sheet in PDF form.
Specifications
RMS Power 12.5 VDC Input
Hi Level w/ Smart Engage
Low Level Input
Crossover(s)
Hi / Low @ 85Hz - Fixed, Defeatable
RCA Output
Full Range Only
2 Ohm Load 90 w x 2
4 Ohm Load 45 w x 2
Bridged 4 Ohm Load 180 w
Dynamic Power 14.4 VDC
2 Ohm Load 140 w x 2
4 Ohm Load 70 w x 2
Bridged 4 Ohm Load 280 w
Dimensions (with ISO Feet)
9.4" x 9.75" x 2.1"
23.9cm x 24.8cm x 5.3cm
richgonfishn
richgonfishn
Sacramento, CA
ngsm13
BP1Fanatic
BP1Fanatic
