RE Sub "PLEASE READ"
since you have a dual 4ohm sub. i dont think you'll be getting the most out of your amp which is rated at "180watts @ 4ohms" you can only wire at 2ohm or 8ohm load. anyone please correct me if im wrong.
Here is what their going with. The only thing is this years model will be here in a week or so. They suggested I wait the week and get the newest MTX 311D.
What are your thoughts?
Thunder311D Class D Amplifier
This subwoofer amplifier features MTX Audio's Adaptive Class D Technology for large power numbers from a very small footprint. Thunder311D features an 18dB/octave low pass crossover, fixed at 85Hz, this amp also contains both the Thunder EQ bass boost and RCA outputs for daisy chaining multiple amplifiers. Our "Smart Engage" auto-turn-on circuit makes installation easy.
Download Owner's Manual in PDF form.
Download the Quick Install Sheet in PDF form.
Specifications
RMS Power 12.5 VDC Input
Hi Level w/ Smart Engage
Low Level Input
Crossover(s)
Low Pass @ 85Hz - Fixed
Thunder EQ
RCA Output
Full Range
2 Ohm Load 200 w x 1
4 Ohm Load 100 w x 1
Dynamic Power 14.4 VDC
2 Ohm Load 310 w x 1
4 Ohm Load 155 w x 1
Dimensions (with ISO Feet)
8" x 9.75" x 2.1"
20.4cm x 24.8cm x 5.3cm
richgonfishn
richgonfishn
Sacramento, CA
ngsm13
