RCA Cancellation Issue
  • 4
Mr.SoloDolo
When running RCA's from Amplifier to LOC (line out converter) Full signal is received only wen one side of the RCA is plugged in.
If both RCA's are plugged in there is complete cancellation of signal..
Any Ideas on how to fix this issue??
P.s. problem is not the rca's i've switched those and problem still remains
polarity is reversed on one of the wires. that requires swapping the positive and negative on one pair of speaker wires into the LOC.
This sounds about right, I was afraid of this so
I guess i'll have to remove the solder and re-do them....
this is same issue i had on my first system setup years ago. exactly what he said fixed it ^^^^^^^
No make or model number on it? Do you have an exact picture of the rear and all its glory?
691
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
691
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
601
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
761
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
909
Mr.SoloDolo
Mr.SoloDolo
Marin County, Ca
eb2phkingood
    May 19, 2024
    May 19, 2024
