RCA balance problems
  • 1
Tjk
Simcoe
Hey first time post here, any help in troubleshooting would be appreciated, bought a car that has a system in it, everything worked great. I have 2 speakers in the front with tweeters and a sub in the back, there are no back speakers. Everything worked great until recently my left door speaker cut out. I took the panel off, checked the wires and one was loose, i tightened it back up and put everything back together. I noticed my left right balance doesn't work, it will go one way but not the other, if I flip the RCA's it has the opposite effect. I figured maybe it was a loose cable at the head unit so I took it off and checked. That did not seem to fix the problem. To be safe because I was in there anyways I had 4 RCA's 2 of which were not in use so I switched them to the other 2 and same as on the amp. When balance is center it does play equally through both speakers, but when I try l/r balance I run into the same problem one side goes deaf and the other plays. The odd thing is it plays both speakers through one RCA. I think it may be the amp but you would think it would cut out both speakers if it was an amp problem? Any help would be appreciated thank you
No make or model number on it? Do you have an exact picture of the rear and all its glory?
526
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
492
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
471
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
678
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
769
Tjk
Tjk
Simcoe
Tjk
just call me KeV
    Apr 27, 2024
just call me KeV
    Apr 27, 2024
