RCA and remote question *PIC*
Insomniac119
i can't sleep
The RCAs I got have a wire for the remote in between the left and right wires. Is this ok to use?
Nope, I don't know who made them but Lightning audio sold them //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.
Although that wire can be used as a remote on line its actual intended purpose is to connect the chassis of the amp to the chassis on the head unit in an effort to further reduce the possibility of noise, on some amps you will find a screw beside the inputs that seems to have no purpose this is the intended mounting location on the amp and anywhere on the chassis of the head unit.
99.9 percent of the time this is not necessary so you might as well use it as a remote wire.
Although that wire can be used as a remote on line its actual intended purpose is to connect the chassis of the amp to the chassis on the head unit in an effort to further reduce the possibility of noise, on some amps you will find a screw beside the inputs that seems to have no purpose this is the intended mounting location on the amp and anywhere on the chassis of the head unit. 99.9 percent of the time this is not necessary so you might as well use it as a remote wire.
And to think, I always thought is was a remote wire (thats what the packaging said it was), but used it in the manner you describe to help reduce the possibilty of ground loop problems //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
//content.invisioncic.com/y282845/emoticons/word.gif.64b12e39f936af3b4fff38a1c0bd0244.gif
Originally intended for noise rejection. But, since nobody ever used it for that, they started using them for useful things (like the REM wire).
Hello I have Installed Pioneer ZF-9350 BT With 3 Amps Separate for Front Rear and Sub I checked with volt meter their is NO Voltage coming...
No make or model number on it? Do you have an exact picture of the rear and all its glory?
8
831
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
842
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
720
Insomniac119
i can't sleep
Insomniac119
Wichita, KS
squeak9798
