frankiebones
here we go, 2003 Audi A4 w/o Bose upgrade, quick note, the rear deck speaker is a piece of sh*t 8" sub that will be cut off, so I just did 2 sets of components for the doors. This is my first car audio 'anything,' so if I forgot anything, let me down gently, lol. The parts and wires and whatnot will be taken care of by the installer, I was told to get the speakers, sub, receiver, and amps and to let my buddy (a professional installer) worry about the rest.
Alpine 9856 Receiver w/ iPod link (installed and sounds sick!!)
» CD player with built-in amplifier (18 watts RMS/50 peak x 4 channels)
» Bass Engine (bass cntr freq., width, & level, treble center, freq. & level adj.)
» BBE processing
» three sets of preamp outputs
» Source Tone Memory
» CEA-2006 compliant amplifier
» CD frequency response: 5-20,000 Hz
» CD signal-to-noise ratio: 105 dB
Pioneer TS-C160R Component Speaker Package (2 pairs for the 4 doors)
Sensitivity: 90 dB
Frequency Response: 25-32,000 Hz
Recommended RMS Power: 60W
Peak Power Handling: 250W
Impedance: 4 ohms
The 4 component systems are driven by a:
Kicker KX650.4 (more than enough power obviously but I will keep it far from cranked)
» 4-channel car amplifier
» 120 watts RMS x 4 at 4 ohms (170 watts RMS x 4 at 2 ohms)
» 325 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
» cooling fan
» 2-, 3-, or 4-channel output
» Tri-way capable (Tri-Way Crossover required)
» speaker- and preamp-level inputs
» variable front & rear high-/low-pass crossovers
(variable 50-200 Hz, 12 dB per octave)
» variable bass boost (0-18 dB) centered at 40 Hz with wired remote control
» three-way protection circuitry
Single 10" Alpine Type-R SWR-1042D
» 10" 4-ohm subwoofer with dual 4-ohm voice coils
» Kevlar-reinforced pulp cone with Santoprene rubber surround
» cast aluminum frame with perimeter venting
» frequency response: 26-600 Hz
» power handling: 200-500 watts RMS
» peak power: 1,500 watts
» sensitivity: 83 dB
» top-mount depth: 6-7/8"
» sealed box volume: 0.5-0.8
» ported box volume: 0.6-1.3
It will be slightly underpowered, but my boy Vito has the same sub with ~350W pushing it, and it sounds ridiculous.
Enclosed in a Q Logic QLH-1.0010SE sealed box. unfortunately, I was lied to by the salesmen, who offered me a $70 enclosure for a small fraction of the price, and what I was told to be an enclosure with .65 cubic ft of space (which is dead center in the .5 - .8 range alpine recommends) was actually an enclosure with 1.0 cubic feet.
I'm not sure what I am going to do about this yet, and the unnamed audio store was not open today (sunday).
Pushing the sub, I have a Kicker KX400.1 mono amp.
» 200 watts RMS x 1 at 4 ohms (400 watts RMS x 1 at 2 ohms)
» variable low-pass filter (50-200 Hz, 12 dB per octave)
» variable bass boost with wired remote (0-18 dB at 40 Hz)
» switchable subsonic filter (12 dB/octave at 25 Hz)
» preamp outputs
I paid only $200 for this amp bc my buddy has given a particular store in NYC a ton of business.
However, 3 days ago, I bought the newer model at Circuit City, the ZX400.1, for $350 including an additional 2 years of coverage through Circuit City's extended warranty program. The diff. in $ is significant, but just in case anyone thinks I should go with the newer model despite the price, here are the specs on the ZX:
» mono subwoofer amplifier
» 200 watts RMS x 1 at 4 ohms (400 watts x 1 at 2 ohms)
» variable low-pass filter (50-200 Hz at 24 dB per octave)
» variable bass boost (0-18 dB at 40 Hz)
» subsonic filter (12 dB at 25 Hz)
» wired remote bass level control
» Class D design
» speaker-level inputs
» preamp inputs and outputs
» fuse rating: 40A x 1
So thats all of it, the new receiver, the 4 component speaker sets, the 4 channel amp to push them, the alpine sub, and the two mono amps I could push that with.
» BBE processing
Sensitivity: 90 dB
Impedance: 4 ohms
» cooling fan
» preamp outputs
» Class D design
