Random Picture Thread
Fi made some cool t-shirts.
@audiobaun, did you notice the 16 US Acoustics amps? He clamps 94K and does 180.7.
Had one at a cabin we rented. It couldn't keep the doom fridge and lights going. We used it to run ceiling fans and rhe box fan. We literally turned everything off minus the fridge to keep food cold and it struggled. Worthless for anything else. Maybe a small camper but when the dorm fridge kicked on it died several times.
Figure your load need then go up one size bigger IMHO.
It would just be for a Skil Saw and a small compressor.
It says 2,000 watts. I only need something for a Skil Saw and maybe a small compressor.
Thats 2k max not continuous power though. For $400 bucks .. Id spend the coin on something that will run both or even be able to use in a power outage and get a 3 yr warranty. But hey.. thats me. That joker you are looking at looks worn out for $400 bucks
That fridge was rated at 13 amps. That would be at start up and it killed it several times, not all the time but it did several times. Only had the led bulbs in the kitchen on. It was about a 400sqft cabin.
I'd hesitate to say you could run one and start the other because of the initial amp draw.
I have small compressor and ill look at amp draw in the morning but I know my worm drive saw will trip a 15amp circuit every time if I use a 14g extension cord. I have 12g now and its fine but it draws at lot at start up.
No need to check. After hearing what you went through I will pass on it. Thanks for letting me know man! Have a good day!
There a few online calculators but the numbers are all over the place.
Northern tool has one https://m.northerntool.com/shop/tools/buyers-guides_wattage-calculator
As does generac. I'd error on the high side, it suxd needing it and having to turn off the lights to restart it when the fridge kicked on. Very frustrating especially while on vacation.
Slo_Ride
Regulator
Slo_Ride
ATLANTA
ThxOne
vegang
vegang
