Quick firewall question
98 accord, right now I have 8 guage and its ran through this hole on the left (passenger) side kinda under the fuse box, kinda deep and there's a lotta stuff over it so I can barely see it through all the stuff, just followed the 8 guage with my hand. Not even sure if I will be able to fit the 1/0 though. But yeah it didn't seem sharp at all, plus there are other wires being ran through there too
run it with the other wires, i would, no need to drill if a hole is present, if its stock then its protected
btw.. i have 3/0 wire going thru my firewall with no grommet i drilled the hole and clean as i could and shaved it with sandpaper, the reason there is no grommet is because to squeeze the wire thru i had to drill in between two bolts by my fuse box and thats the largest i could go, with the grommet in place i couldn't get the wire thru, i did wrap some tape around it tho just to help
thai_creeper
thai_creeper
bay area, ca
Decipha
