questions
I went with the BX1205D I have heard it is a little overrated, but I have also heard they are reliable and it has a lot of nice features. Plus at 1200RMS i don't care if it is overrated it is plenty of power for a first amp.
I wouldnt go that low, maybe aim for 28-30Hz, with a tuning of 32Hz your sub could bottom out at 24Hz...
As for the phase knob, it is if you are going to invert your subwoofer, it switches the + and - . Have it set to 0 unless you plan to invert.
I beg to differ. I think 24-25 hertz would be the sweet spot for a box tuned to 32 hertz. Good luck with the setup though jd.
I understand 0 would be normal and 180 would be inverted I'm just wondering why can you chose a setting between 0 and 180 such as 100 for example that doesn't make since to me
jd_man_90
Rollin on 14's
jd_man_90
Trenton, Fl
kenneth
