Questions regarding Gain settings for 4-channel
bikinpunk
G-g-g-g-g-unity!
I've looked through and searched the tutorial but couldn't find a specific thread on my question:
First off, my amp is rated at 40w rms x4 @ 4 ohms. My slc's can take 100 @ 4ohms. If it's possible to boost my output by setting the gains a little higher I'd like to. I'm wanting to run active 2-way and I want to give them about 50w each (50w for mid1, mid2, tweeter1, tweeter2) and not stress my amp too much.
I understand that if I were setting gains for one speaker the gain voltage should be approximately:
SqRt(50*4)=20v.
My question, is since I am actually pushing two speakers off each set of channels (front set off channel 1 & 2, rear set off channel 3 & 4) should I be doubling my output power to account for this since I have one gain control for each set of channels (once again, gain for channel 1 & 2, gain for 3 & 4)?
Ie: SqRt(100*4)=40v.
If this is correct, then each channel should be showing 50w each after all is said and done, correct?
I'm sorry if this is confusing... I tried not to make it that way.
If I'm completely wrong here, please explain to me how to set this. Thanks guys.
Edit: I think I made this much harder than it is. I can set one gain while checking voltage at one channel instead of worrying about both, since it should be the same on the other channel.
Still, I need advice on whether or not I should try to push my amp at 10w more than what it was rated. It may not be a major difference, but Rainbow's site says "minimum amplifier power 50w".
Setting higher gain doesn't allow the amp to make more usable power than it would with properly set gains.
Thanks for the info.
I hated to be one of those "turn the gain all the way up", but I thought it might be a viable solution. Now I know better.
bikinpunk
G-g-g-g-g-unity!
bikinpunk
Alabama
bikinpunk
Mike Mccabe
