questions questions questions
wereami_
LA
ok so heres the deal...im looking into buying 2 orion hcca 15ds and running them off of the orion xtreme 1400.2 amp at 700x2 @ 2ohms. im going to be installing it my self. im new at car audio so please feel free to suggest any changes in the system. anyway im not real shure on how to set the ohms.....if anyone can help me it would be nice...thanks alot...
well honestly unless you have a chunk of change and you dont know what else to do with it i would prolly go with something other than orion for the money your going to invest you can pick up a nice setup. but if you really want to go orion (not that i have anything against it) and i was wiring them i would wire my subs parallel to push everything that those subs can handle i have never owned orion but i heard it takes alot to break those subs in so then i would run my amp 2 ohm mono and im almost positive all highier end orion amps only run on 4 gauge eithier way i dont suggest running on anything less hope that helps...
wereami_
wereami_
LA
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
