Questions on sa12
This is a very documented topic on these forums. The search function is your best friend.
BUT, they like 2 Cubes each but that can change depending on the power. As for power handling... I've seen people throw up to 1.5k daily, but it has to be a very clean signal. Anything beyond that and you would really be pushing it.
so a aq2200 to 2 at 1 ohm should be okay?
---------- Post added at 08:30 PM ---------- Previous post was at 08:29 PM ----------
do you enjoy yours?
long as you are careful with the gain they will be fine i usually stick a saz1500d on them which puts out 1900ish watts to the pair.
do you enjoy yours?
That should be fine, but just make sure its a good, unclipped signal. I would also advise breaking them in before you wail on them with 1100+ watts a piece.
And I love mine. I'm only pumping 650 a piece into them, but I was considering the AQ2200 or something similar for a summer upgrade.
ScionIq
ScionIq
Newport Richey, FL
fatboytyler
BP1Fanatic
BP1Fanatic
