smjromano
Well I'm now getting the question asked by my friends, "You're STILL working on your stereo!?!?!" So I really need to make the finishing touches...
I have a 2003 GMC Sierra Regular cab, base model 4x4
The stock alternator is 105A
The stock AC Delco battery is 725CC
I have 2 10" Kicker L7 4 Ohm DVC subs (2400 Peak Watt/ 1200 RMS) wired at 1 Ohm to a Massive N3 amp (2800 Peak Watt/ 1400 RMS)
I am in the process of creating my shopping list for the Big 3 Upgrade, alternator and battery (In that order from what I have researched)
Question 1) With the Big 3 upgrade, I have researched that a fuse should be added between the positive alternator and positive battery. What size fuse should I get? Where do I get it (link or details please)
Question 2) What High Output Alternator should I get? I have done little research for this part.
Question 3) I have researched that the Kinetic HC2400 battery would best match my stereo set up. Is this true? What about XS Power? Model size? Also, if it is recommended that I DO go with an HC2400, will it even fit under the hood of my truck as the primary battery or will I need to make mods?
Thanks everyone in advance for their opinions!!!
Take care,
Scott.
Take care,
Scott.
