Question with Direct Leads.
  • 5
I have a Skar 1500, and a psi 18 PF2 dual 2 with direct leads. I wired each voice coil + and - to its own + and - on the amp speaker inputs. Is that right? Do I need to use the outter + and - for 1 voice coil and the inner + and - for the other voice coil? I know its a noob question but ive never had direct leads. I am aiming to be wired at 1ohm
Well, direct leads have nothing at all to do with the ohm load you wire your speakers at. That's just an alternative fastening method.
If your amplifier is a mono amp with dual positive and negative outputs (not inputs), then they are connected in parallel inside the amp. That said, if you wire one 2Ω voice coil to one set of speaker outs and the other VC to the other set of speaker outs then you will be at 1Ω.
As for which + and which - to use on the amp, it doesn't matter because electrically speaking, they are the same points, respectively.
484
Nothing to add to this, Just wanted to say good luck and that I miss MiniDisc. OH!! Is that a Japanese Radio Tuner or does it get stations in the US?
784
That would be fantastic! Id love to see the skills involved here. It always intrigues me to see some customizing from small and detailed to large...
537
93Exploder
93Exploder
Turlock Ca
93Exploder
    May 12, 2024
Brendon Jenness
    May 11, 2024
