question on wattage
way2loud28
ok i have two rockford p3s and their are dual 4 ohm voice coils. the rms on these subs is 500 watts so does that mean for rms wattage i have to do 250 to each channel or does that mean 500 watts to each channel, peak on these subs is 1000 watts
its basically the only audio place in my are other than a few small places that only carry mephis, should i try looking at those i was juss tryin to match my subs but if that is over priced ill take a peak at other places
this amp would work alot better and it's cheaper. plus it's underrated so it'd push more than 400@2ohms and you can get it for $230.
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13470
btw, your best bet is to buy online. it's the cheapest way. retail stores charge out the *** for overrated products (memphis isn't overrated, but hella expensive even retail).
there are some mono amps with 2 "channels" and each "channel produces power, so you can "bridge" the 2 "channels".
but those ratings are at 14.4 so it's a lil overrated. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
the orion would be your best bet. i still say.
way2loud28
way2loud28
H-town
dkguitarist
