nofriends46 10+ year member
Whats Power Distribution Block, whats that for.. hook it up etc...
Also my Punch 500a, has preamp outputs, does that mean you can hook up another rca cable to that amp instead of running a Rca cable to your other set of rca to your Head Unit?
Bass Blockers, do you need like 2 of them, one to postive and one to negative or just one? If you need one, how do you hook that up. If anyone used this, does it really work? Also its says if you want 300hz, 600hz, 800hz etc.. and 4ohm and 8ohm. What is the difference between 300hz and 600hz etc... and 4ohm to 8ohm?
Thanks!
Thanks!
