Question about strapping....
mgcauctions09
I have 8 alpine type r 10's. They are d4. I dont think I can wire them all together for a 1 ohm load. I think I can get a 2 ohm load though. My question is If I take a aqx35001 amp and strap it to another one, If I put all 8 subs with a final load of 2 ohms to both amps, does that make each amp put out 1 ohm? (I mean do they split the 2 ohm load or how does that work)
you can wire all 8 up individually in series, then the dual 4's will become single 8's, then you can parallel all 8 pr of speaker wires to a 1 ohm final load //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
and yes a final loud of 2 ohm would present 1 ohm load per amp, but you dont have that problem here if you have eight dual 4's //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
that would also work. I just "assumed" he wanted more power for the subs...
yeah eight subs would get what 150w per coil off around 2500w? blah!
my 2500d's arent strappable //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif boooooooooooo
my soundstream 2000d's are though //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif yayyyyyyyy
How do you figure. I need a final 2 ohm load not a final 1 ohm load.
I am confused............So basically if I can get a 2 ohm final load off all 8 subs and hook them up to the 2 aqx35001 amps each amp will be seeing a 1 ohm load thus in return sending 7000+ watts to my 8 subs.
oh my bad i didnt know you had a 2 ohm requirement. strap your amps @ 1 ohm total, running each @ .5 ohm, I bet box rise will make it pretty much ok to do this. Then you will get more out of your amps, provided your elec is up to snuff.
Yeah thats probably what I will do. .5 each //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
up to snuff really jason lol
my boy blew all 4 of those Am Bass 12's, ran into money problems, and sold me his two SoundStream2000D's and four aeroports for teh CHEAP //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif//content.invisioncic.com/y282845/emoticons/redface.gif.62fdbfe1a101588a808c4cff71bcb942.gif
mgcauctions09
mgcauctions09
alabama
CRXBMPN
    Jun 20, 2026
    Jun 20, 2026
