I heard that using Liquid nails on the corners of your box is not a good Idea. They say that it has chemicals that can deteriorate your sub. Is there any truth to this? Or is it just something smeone made up?
you really shouldnt need to use it. u should use wood glue to connect the wood, and silicone to seal the corners. liquid nails doesnt make a chemical bond like wood glue does.
to actually answer your question about whether using liquid nails deteriotes the surrounds, yes. But only if you put the sub in the box before the glue has cured, there is a chance it will detiorate. Silicone is even worse, be 100% sure that has cured before you put the sub in. I use both liquid nails and silicone for sealing/gluing and just wait 24 hours with a fan on it before i put the sub in. I've learned the hard way.
the silicone seales your box. for a lot subs, your supposed to let the silicone completely cure first, or the fumes eat away at your surround. however, some companies like jl, are protected from these fumes.
hdave it will not make a difference if the sub is pounding or not... the chemicals(read:fumes) will still be getting on the sub. as for the silicon, read my last entry in this thread. seroiusly. also, it will do it from the moment you set your sub in until the moment it cures. However i should say that it is worse on foam/compound surrounds more than the rubber ones.
