Another check my box calculations with pics (sketchup) post
amedeuce
:crap:
This is for a 12" magnum
I'm hoping that I did this right and the box is around 1.8 cubes net tuned around 30hz.
the box is 24x16x17 outside dim. WIth 3/4 inch mdf.
The port is 14.5 x 2 and around 48 inches of port if I measured correctly.
Here are the sketchup pics
Look of box
Outside dimensions
Top View
side view
lol ameduce... my greatest condolences for not being able to design you one.. i still don't have AutoCAD on my computer, or else I would have designed you one already //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Very sorry! if you still want me to, i'll try to download a copy and get one done for ya //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
well are you saying this isn't right?
No i haven't checked it. I'll run it through right now...
volume before sub displacement: 1.85 cubes
i'll take out .07 for sub (that's the actual displacement for SI Mag 12's
if you have 1.78 cubes after displacement, and your port is 48 inches, you have a tuning closer to 28.5 hz.
checking your port length measurement...
vertical one: 15.25 (this is from the opening to halfway through the joint)
horiz one: 2.75 (halfway through first joint to halfway through second joint)
vert two: 13.5 (halfway through second joint to halfway through third joint)
horiz two: 2.75 (you get the idea...)
vert three: 13.5
horiz three: 1.75 (halfway through last joint to opening of port into box)
add all together and get 49.5
you have a 1.78 cubic foot box tuned to 28 hz after you drop the sub in.
This is all straight from WinISD
if you want a different tuning, design a new one and take off about 5" of port. That will probably get you to 30hz
vert three: 13.5
Thanks!!! So I was (am) very close to what I'm looking for..
Can I just knock off 5 inches from the first part of the port.
And I already had the sub displacement figured in at .1 cubic ft..
Thanks!!! So I was (am) very close to what I'm looking for..Can I just knock off 5 inches from the first part of the port.
Yea man I just did the figuring... You'll be really close to 30. Like 29.5 hz, and that's a good tuning.
Make the piece of wood that is nearest the inside of the box 5" shorter. This one:
amedeuce
:crap:
amedeuce
CA
JimJ
