question about amp with external fuse
  • 2
treefitty
I have a Hifonics Z8000 (5 channel), but the amp does not have a fuse on it. Hifonics recommends a 50 amp external fuse. This is my first amp with an external fuse as all my previous amps have had fuses on them.
(1): Is the external fuse the same thing as the fuse on the power wire at the battery or should there be a seperate external fuse near the amp?
(2): This question applies if the answer to the first question is that the fuse at the battery is also the external fuse for the amp.
I have an amp kit that came with a 60 amp fuse. Should I swap this out for a 50 amp fuse or is the 60 amp OK?
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
532
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
5
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
9
Haven't 100% landed on which one, but I am down to those two
12
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
8
treefitty
treefitty
in a cave
treefitty
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
