Punch 360 Amp and a 10" Type-R
jaymann107
I'm new to this forum and figured I would start by showing what I have so far. Nothing compaired to alot of setups I see on here but I still hope you all enjoy. Any and all comments are welcome.
Car is a 2001 Acura 3.2 CL
Here are some of my older setups
I figured I will throw tese in here also "My many cars"
1987 Cutlass Supreme
350 bored 30 over
The Hoe/Tahoe
I've never noticed the rim on the Tahoe but I'm pretty sure it was not bent because those tires were brand new and the shop that installed them never mentioned a bend. And from the looks of it I would hope i would have noticed a bend that bad. Good eye though.
I believe it is the Sony CDX-GT630UI but it might be older than that one I will have to look and see. And honestly I'm not very happy with it, the only reason I bought it is because at the time this was one of the few headunits that had the USB port for my mp3 player.
It looks good, nice clean setup. I love those amps, I have one in box that has a burned out transiostor that I need to fix.
Oh, and in my opinion I would hide the cap away, I don't like putting caps on display.
did you do all the installation? how hard was it to bypass the factory amps with that bose? my girl has a 97 3.0 CL right now i just have a LOC installed with her factory system
Thanks for the comments guys. I think I will hide the cap. As far as the installation goes I did it all myself. The factory amp is not bypassed, it's currently running my aftermarket 6.5 components up front (I know they can sound better though) and my after market 6x9's in the back (Which sound great) and I'm more than happy with the way my mids and highs sound. On another note I know my factory system and your girls 97 system are completely different. And right now I'm running my system off of a LOC also because my headunits RCA outputs do not work.
Go to http://www.acurazine.com
and you can find out everything you need to know about your girls car and any other Acura for that matter.
I figured I would throw this in here, I consider these my pride and joy
The 10" Type-R sounds good with my little 360 pushing it but it is only 2 weeks old and I have not pushed it hard because I want it to break in a little first. As for the SQ I am very happy with it, once it breaks in then I will see what it's made of.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif As for the old skool Punch 200 that is going in as soon as I feel the Type-R is ready for it. When I lived in Miami all me boyz had these punch 200's pushing everything from two 12" kickers in a honda accord to 4 15" kickers in a ford explorer. Trust me I know what these older Punch amps are capable of that's why I've been sitting on them.
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
Class A/B, right? If I recall, these little 2x30 watt jems could best several hundred watts, mono. One of RF's endearing qualities on most of...
879
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
218
jaymann107
jaymann107
Orlando, FL
jaymann107
    Jun 3, 2024
