problem
rarmstrong
JERSEY
hey guys i encounterd a problem recently....i just put in my new hu (eclipse 7000) new 4 gauge wiring kit and just rewired my xxx to 1 ohm...for some reason i cant get any bass...it was working the day i rewired my sub but then the next day i cant get anything...any body no what i can do...i checked everything
check your grounds first, then check to see if you blew the fuse under the hood....where are you gains set on your amp, where is your subsonic filter set, and where is you highpass filter set, what are the settings on your HU and are you sure that the sub is wired correctly within the box and all connections are secure
Reid, I know some headunits have the ability to turn off the rca's powering the bass, or turn the bass down to 0 or something. Look in the eclipse manual and see if it says anything.
If you park behind the woodshop tomorrow we can try a couple things if you want. Busy after school, and definetely know nothing compared to Dave, but can check out your grounding points and stuff.
rarmstrong
JERSEY
rarmstrong
Manasquan, NJ
budget76
BP1Fanatic
BP1Fanatic
