problem with subs exerting each other out in wall
phemps
i just walled my car with 8 tens. the box is sealed and the box is a little bigger than the recomended net volume for the subs. when i turn it up to a certain level the subs start to move at different time and go out of control. is this unloading? is the improperbox size causing this? its not too much bigger than recomended
theyre in series parralllel and im pretty sure theyre all in phase. it only happens when i start to turn it up more
You need to pop the wall with a batt, series/parallell is easy to screw up, esp with that many subs. I did it with 8 dvc 8's, and you gotta watch what you doing
ok good idea ill try it. i def see how i could have messed it up casuse the wiring was pretty intense i took my time but who knows i could have messed up. but is there even a way to accidently screw up polarity in a series parallel circuit without changing the final ohmm load? i thought i had it down
All you have to do is switch 1 neg and pos around, and you screw the whole thing up, and sometimes it wont affect final ohm load if you reverse it
alright i have to see if i have a battery laying around
phemps
phemps
PA
Immacomputer
