Problem when calculating Sealed Box design..
microhaxo
So I bought a new car and I no longer have room for ported, which is fine. I decided to calculate out the best sealed box for my sub and so i went here:
Car Audio - Sealed Subwoofer Box Design Calculator
and used these specs:
AV12X-D2
FS: 26.7Hz
Qms: 3.67
Vas: 69L
Cms: .22mm/N
Mms: 161g
Rms: 7.32
Xmax: 23mm
Xmech: 32mm
Sd: 471sqcm
Vd p-p: 2.16L
Qes: .36
Re: 3.2ohm
Le: .196mH
Z: 4ohm
Bl: 15.6Tm
Pe: 1000W
Qts: .32
1WSPL: 87.7db
2.83V: 91.7dB
I also used
AJ Sealed Designer to make sure the response was right.
Now here is the problem.. If i use a normal Qtc of ~ 0.8 - 1.2 my box IS HUGE, anything above 1.2 Qtc and now im peaking at like 1khz.. wtf
The flattest response requires a 67cu ft box! even at 1.2 Qtc i need 5.282 CUFT SEALED!!!
I was looking to make ~ 1.5 cuft sealed for the sub but now it seems that that design is WAY too small for this sub.
Someone please help me.
Thanks.
EDIT:
Here is the same result with WINISD:
Uploaded with ImageShack.us
microhaxo
microhaxo
MINNESOTA
microhaxo
BP1Fanatic
BP1Fanatic
