Problem using DMM to set gain on JL 1000/1
john.mulvehill
I am setting the gain on a JL 1000/1v2 using a DMM according to the instructions on page 14 of this pdf
I am using a 50hz 0db sine wave test tone on repeat and I have the head unit at 3/4 of the max.
However, when I hook the DMM up to the the subwoofer outputs according to the diagram and set the DMM to AC Volts, I get readings between 91 and 98 volts. I can't get the volts to drop below 91 even when turning the gain down. Why wouldn't the volts be dropping down to zero when I have the gain all the way down? I am trying to get it to a target value of 54.7 volts.
Any help would be appreciated.
Thanks.
check your head unit settings, if you have high pre-out voltage, the sub control all the way up, or your bass control all the way up you may get ridiculously high numbers due to clipping. I once couldn't reach the needed voltage because the HU was set to -10 on sub bass without me knowing.
john.mulvehill
john.mulvehill
Philadelphia, PA
john.mulvehill
michigan born
    May 14, 2026
michigan born
    May 14, 2026
