J jagblazer01 10+ year member WOOO BASS!! 739 0 Baltimore, MD Jan 6, 2008 #1 we did my buddies big 3 on his ranger today and for some reason instead of helping him, his voltage dropped....cant figure out why. any ideas? Click to read more...
bad @SS chevy 10+ year member CarAudio.com Veteran 2,861 0 ohio Jan 6, 2008 #2 Maybe the grounds are loose? Check everything, I just got the big 3 done today by themommyvan and my voltage barely drops at all now.
OP J jagblazer01 10+ year member WOOO BASS!! 739 0 Baltimore, MD Jan 6, 2008 Thread Starter #3 i checked everything before we started the truck and all connections were tight
B blackbonnie 5,000+ posts The Revolution 10,292 2 Grand Rapids, MI Jan 6, 2008 #4 but you need to check everything after you did it to ensure you did it right
OP J jagblazer01 10+ year member WOOO BASS!! 739 0 Baltimore, MD Jan 6, 2008 Thread Starter #5 im almost positive i did everything right......battery + to alt., battery - to engine bolt, battery - to chassis.
bad @SS chevy 10+ year member CarAudio.com Veteran 2,861 0 ohio Jan 6, 2008 #6 did you leave the exsisting wire?
B blackbonnie 5,000+ posts The Revolution 10,292 2 Grand Rapids, MI Jan 6, 2008 #8 its battery + to alt , battery - to chassis , chassis to engine bolt
skrilla22 10+ year member CarAudio.com Elite 588 0 Tacoma, Washington Jan 6, 2008 #9 thats the same thing he just said blackbonnie, just your grounding the alt using the battery negative. Same way I did mine.
B blackbonnie 5,000+ posts The Revolution 10,292 2 Grand Rapids, MI Jan 6, 2008 #10 it is the same thing, both ways serve the same purpose
OP J jagblazer01 10+ year member WOOO BASS!! 739 0 Baltimore, MD Jan 6, 2008 Thread Starter #11 so anyother ideas??
OP J jagblazer01 10+ year member WOOO BASS!! 739 0 Baltimore, MD Jan 6, 2008 Thread Starter #12 he's running a yellowtop in the front of his truck
themommyvan 10+ year member Special Olympics winner 1,544 0 Belleville,MI Jan 6, 2008 #13 If you fused the alt to batt make sure that fuse is good and that its rated high enough
OP J jagblazer01 10+ year member WOOO BASS!! 739 0 Baltimore, MD Jan 6, 2008 Thread Starter #14 didnt fuse it
KINGDELL91 10+ year member KING OF KINGS 2,572 0 Detroit, MI Jan 6, 2008 #15 might want to fuse it just in case!!!
