preouts the problem?
ls_monk
I have a pair of Kicker 12" xpls running off a Pioneer 800 watt amp. Once the bass starts pumping the protection turns on and the subs cut out. I have switched the subs out for other ones, still. Swapped the amp for a kicker 4 channel. I bridged it to the one amp, still. The headunit is a kenwood kdc-x915 It doesn't have an internal amp. Everything works great till above volume 25. The door speakers amp works great right up to 35 doesn't cut out. I tried switching the Non-fading preouts with the rear to see if the problem still happens. And it does. So the only thing left is to sweap the head unit with someone and see. Has anybody had this problem before?
thanks EH!
No they are 8ohm subs wired for 4ohms. So I know thats not the problem. The lights don't really dim. I don't think 4 ohms would need that much power. Would they?I am running 10ga wire and cheap RCA's
ls_monk
ls_monk
wINDSOR, ON
ls_monk
