Pre-out question
  • 2
BMG
here
I have 3 sets of preouts on my deck. One full range for front and one for the back and then a sub pre-out.
I just put an amp on my front stage and used the front set of preouts off my deck. I was wondering when i get my sub amp would there be any difference between using the preout off the amp i currently have installed and using the sub preout off my deck and running another set of RCAs through my jeep? i mean, what difference can there be in the preouts cept maybe they have the sub preout set to lowpass already? so if i used the preouts off of amp1 and set amp2 to lowpass it wouldnt be any diff besides the wiring right?
sorry if im not makin much sense, im exhausted and my mind is goin 90mph
i'd use the preouts on your deck... usually they'll have a higher voltage rating plus you'll have some sort of sub control within the deck... go ahead and run the rca's u'll be glad you did
well, i was reading up on audiobahn's site(amp1) and they call them "RCA Throughput connections" which would lead me to believe they take whatever voltage they recieve and then output it without changing it. but on the other hand id never thought about the sub control part. Cuz there is a separate section of controls for it :-/
If you don't use the sub controls and your sub amplifier has a low-pass filter, you don't need to hook it up to the sub pre-out on the head unit. You'll also save yourself some cash by doing so (shorter RCAs = cheaper) ...
yea, time also... considering i'd have to rip up my whole drivers side again :-/
I honestly dont know what kind of benifits i would have using hte sub controls in the deck.... Its an alpine 9811 and the subs i'd be using are 2 12" JLW0s with most likely a JL 250/1 amp powering them. Personally, at that low of wattage an so on, i dont think the deck controls would play that much of a part. Do you guys?
Ive competed in car audio since 1991 and unless something is faulty in the amp and its staying on all the time it wont drain your batteries ..the...
I just bought an Alpine R-A75M for my sub woofers, and later plan on adding the Alpine R-A60F. My plan was to wire these with 3 sets of RCAs; one...
yeah that, just as long as your amp can take the voltage. I have an orion amp that maxes input voltage at 4V.
Sounds like you need new coils. My Explorer with three 15's, appropriate birch box, fully sound-deadened interior, and a boat behind it does not...
BMG
BMG
here
BMG
