Power wire how long between cap/amp?
31337hxr
What should be the distance between a 1.0 farad capacitor and an amplifier in terms of the length of the power/ground wire?
My current setup is:
JBL BP600.1 Mono Amplifier
4 gauge power wires
PowerAmper Xpower 1.0 farad digital capacitor
(2) Stinger HPM Platinum plated ring terminals
As short as you can possibly make them. The closer the better //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
Oh, total opposite. i play with storage bins full of wire scraps from past installs for fun. I hoard decent grade wires from audio homies...
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
31337hxr
31337hxr
Los Angeles
bass_mekanik
    Jun 1, 2024
    May 31, 2024
