Power Wire Gauge for 2 Amps
dnak24
I need some help determining the appropriate wire size for my power supply. I currently have 1 amp (RE Audio DTX 16001) and 1 sub (RE Audio SE Xv2-12D2) installed from my local shop, but want to also install a new amp and component speakers for my front. I have an Alpine MRP-F300 on the way that i intend to use for my front speakers (not yet picked out).
Would the existing 4ga power supply be adequate for both amps or would i need something bigger? I plan to use a distribution block to the two amps but want to make sure I'm using the correct wire sizes.
I would go to a local shop again but the more I look around this site, the more I want to try and do it on my own. Thanks in advance for any help you guys can provide.
You'll need a fuse distribution block, one that has at least 1 4 gauge output, and 1 8 gauge output.
The RE amp calls for 4 gauge, but the Alpine amp needs 8 gauge. Look for a distro block that say's 1 4 gauge in (from the battery) and at least 1 4 out (to RE) and 1 8 out (to Alpine).
May be overkill for you, but this would do: 2 Way Distribution System
yes you can. It will work just fine. No need to run a new wire at all. Just get your distribution block connect the 4 gauge wire in and then the two power wires out to the amplifiers. I have a 0 gauge going to a block then two 4 gauge coming of of it to the amplifiers and haven't had a problem yet. I also don't have it fused at the block. Just up front by the battery.
dnak24
dnak24
Honolulu, HI
RemmySa12
vegang
vegang
