Power to LC2i but no power to amp.
Nugg32
Ohio
I have the remote wire from the amp connected to the remout IN on my LC2i however I get power to the LC2i but not the amp. I accidently had a few strands of wire hit the 12v port on the LC2i and it powered the amp but obviously that would drain my battery. Any clues as to why my amp doesn't have power off the correct remote connection?
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
474
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
367
756
Nugg32
Nugg32
Ohio
Nugg32
Brendon Jenness
    May 8, 2024
    May 8, 2024
