porting the box or staying sealed???
dflw_99
Kicker Ownage
i have 2 15L7's in a sealed 8cubic feet box. i have four 4'' wide 6'' long aeroports that i thought about using. what would yall do in my position??? i would like to just cut the holes in the sealed box and insert the ports in, would that be ok??
Your ports as they stand aren't suitable, to use all 4 (and you need to use all 4 to keep vent air speed down) they need to be 12'' long, that would tune the box to ~33hz.
You could try just 2 of your current ports, (that would also result in a 33hz tune) and see how it goes, just leave room to add the others if you get too much port noise.
i'd try to rebuild a box and work the ports into it. 4cu each would work fine for those. bigger the better. but 4cu is a start //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
dflw_99
Kicker Ownage
dflw_99
OPP,AL
BOCCOstunna
vegang
vegang
